61 4dr, 144 engine, can i run without radiator......
61 Waycrosscomet
Post by 61 Waycrosscomet »
Hi All, got a 61 4dr, 144 engine, auto trans. stripping as much I can before taking to blaster and getting primed. Was told I could remove the radiator and heater box if I am not running the engine long. Just need to pull out or garage, then up onto trailer, then from trailer into blasters blasting booth.
Wanted ya'lls thoughts and tips. Thanks.
Re: 61 4dr, 144 engine, can i run without radiator......
If you could connect the rad hoses so the motor could circulate water would be much better but yes I have run a motor for a very short time like 20-30 seconds with no prob.
But, I've also seen engines run for bloody ever in demo debys with the rad punched out,, lol.
power band
Post by power band »
... as mentioned connecting rad hoses to circulate would be better but as long as you can limit the running time to get it on and off transport you should be OK . Might puke a little coolant though .
reasonable running and stopping condition is presumed to move w/o coolant. Curious how engine is protected from blaster ?
PICS appreciated ! - Big Fin Comets' are last of MEL signature JET AGE styling cues - too cool ...
... Fins, Fender Gunsights and Tube Radio ..
Image . . Image . Image
BTW = like the 144, my '61 is also a Ford Small Block SIX:
Image. Image
hav e fun
