Good Day! I hope All are enjoying a pleasant one. I was told that the 1100 Carb with One (1) diphragm is for Sixes/6's with Manual Transmissions and that 1100 Series Carbs with 2 diaphragm's are for Sixes/6's with Automatic Transmissions.
Is that True, and if so, can the Man. Tranny version, (single diaphragm) be adjusted or modified for Sixes/6's with Automatic Transmissions?
I have the opportunity to get a great deal on a single diaphragm carb, but I want to know/confirm that it will work on my Six with the double-diaphram Setup.
Enjoy Everything!
john b.
Can I put 1100 Carb for Man Tranny on 200 w/Auto tranny
- 1964Comet404
- Location: upstate, ny - owego (not to be confused with "oswego")
- Contact:
john v. b.
"If it aint' broke... Drive It!" ~ me
"You cannot do a kindness too soon, for you never know how soon it will be too late." - Ralph Waldo Emerson
Re: Can I put 1100 Carb for Man Tranny on 200 w/Auto tranny
I'm sure it would run w/ a slightly different carb. I can't confirm this though, but I don't see why it wouldn't. I'm sure there are many cars out there w/ the wrong carbs on them.
5H25T582252
5H25T582252
- 1964Comet404
- Contact:
I recently learned via Classic Inlines, in their Tech Doc department, that the Autolite 1100 with Spark Advance is somewhat mated to the Load-O-Matic Distributor. Installing a non-spark advance carb without changing the distributor is possible, but the engine will probably run with very poor performance. I believe as per this Autozone Image / Breakdown of Autolite 1101 Carburetor, that the 1101 has the Spark Advance and will work with the LOM Distributor... but as far as other "wrong carbs"... I think the engine will run like Cr.....MattDoscher wrote:I'm sure it would run w/ a slightly different carb. I can't confirm this though, but I don't see why it wouldn't. I'm sure there are many cars out there w/ the wrong carbs on them.
See This: http://classicinlines.com/Loadomatic.asp
...and this: http://www.autozone.com/autozone/repair ... 5280053d79
john v. b.
