as the snow finally melts and i get to my 63 i want to tackle a problem i had last year, when i go into a turn the car stalls,does it more when hot than cold but it will fire up right away. a carb float issue ? any suggestions ?
thank you dave
car stalls in turn
Re: car stalls in turn
I had a 1 bbl on a 300 six cylinder get loose one time. before you open it up to check float, check make sure it isn't just loose. I could push it to the side & make it miss. it would lay over & suck air at the base.
