Bought a 100amp 3 wire alternator
had to drill the lower mount hole but got it to fit(maybe need to carve the adjusment bracket but only a little
ive searched and i havent found a CLEAR answer
this is for an upgrade to a 100 amp 3 Wire Internally Regulated Alternator
ON VR
A# Big yel/blk to A# (or B+) on generator
small yel/blk to generator idiot light
F# small blk/wht to ...field wire? on generator
B+# Big black from +side of starter relay(also battery wire)
small blk/yel... to horn relay
BIG Yellow...??to Ignition, headlight switch, cigarette lighter
SO...
connect ALL wires at VR (Exp small yel/blk idiot light wire) together
(Big yel/blk to B+ on alternator)
connect small yel/blk idiot light wire to light terminal on Alternator
DONE...
???YES?????
clearing up 3 wire 100a alternator wiring
- sharkskinman
OG 62'Comet..not named yet
