Ignition on 64
Ignition on 64
Hey folks. I'm trying to set the timing and the rotor itself has rotational play that I've never seen before. It actually spins 15-20 degrees in both directions before it hits stop on shaft. I have no idea what was done to this car before me so I don't know if the distributor was switched out. Is this normal? Is there supposed to be a clip or something on the shaft to secure the rotor? Thanks.
Re: Ignition on 64
Sounds like the springs in the mechanical advance mechanism under the breaker plate are messed up or broken. Pull the breaker plate out and makes sure everything is there and correctly installed. Are you sure it's not just a loose rotor?
Re: Ignition on 64
The distributor shaft itself does not move. Only the rotor moves. It is the correct rotor for the car. Seems like I have heard there is a clip that is supposed to be attached to the rotor to limit this sloppy movement. See below:
http://www.macsautoparts.com/ford_falco ... comet.html
Do you guys have this on your rotor?
Its got to be the issue.
Thanks
Thanks
Re: Ignition on 64
That is the clip used on a 6 cyl dist. If yours is a 6 which you never said what engine you have, there should be one of those in the rotor otherwise the rotor will be sloppy and timing will be all over the place. Plus the risk of destroying the rotor and cap.
People need to give more info when asking questions as in my case the crystal ball is on the blink.
Re: Ignition on 64
Hey Ron,
Yes sorry it is a 6cyl 3.3L Ok well I'm gonna have to get a hold of one of those little guys. Its crazy what they want for that little clip on ebay. Geez. I figured something was wrong. I really have no history on what was done to this car so if something is missing well its trial and error. Thanks for the input. I will track one down!
