65a alternator
4 prong external voltage regulator
working fine i guess
one night i installed a stereo and appearently the stereo drained the battery enough that it wouldnt start
started it played with it, wouldnt charge enough over short time to restart
charged it
drove it to advance/autozone...wasnt charging(mid 12v regardless of RPM) - bad voltage regulator
changed regulator..hooked voltmeter to battery routed outside with hood closed
also old one Inside
radio no longer hooked up
charging at 14+at idle no lights
turn lights on drops to 12.3 or so (readings are on FLAPS battray/charge tester and voltmeter inside)
checked--said battery no good--changed out battery (all of parts are under warranty)
had alternator checked outside the car and it tested good
Now Everything is testing good Individually
but STILL mid/high 14+ idle no lights
lights turned on drops to mid/low 12s
should i hook an ammeter up?
best place to wire it in?
charging gremlins
- sharkskinman
charging gremlins
OG 62'Comet..not named yet
Re: charging gremlins
Sounds like something is still bad. Do a test of the alt. Disconnect the plug from the reg. Then jumper the F to A temporarily in the plug. That will force the alt to go full max output. Monitor batt voltage. Should see 14+ volts maybe as high as 15 v. That indicates the alt is good. Don't do for more than 15 seconds at a time.
If that works then you still have a reg problem. Hopefully it is not a solid state reg. The older relay type regs tend to be more dependable and always work.
Does your charge lamp, if there is one, light when you first turn on the ign before you crank it? If no charge lamp then check the I term on the reg. That term gets its' voltage from the ign so should show something more than zero.
Does your charge lamp, if there is one, light when you first turn on the ign before you crank it? If no charge lamp then check the I term on the reg. That term gets its' voltage from the ign so should show something more than zero with key on but not started.
