Replacing heater core... '63 I6..
Hello all, I need help/instructions on replacing the heater core... I have a 2 door, straight six. (Haven't figured out how to identify the engine yet). Previous owner said it was leaking. Any help would be appreciated. Thanks.
Re: Replacing heater core... '63 I6..
I'd take the heater box out of the car. h hoses,cables, defrosts ducts ,intake duct & 4 nuts in the engine bay around the blower motor & that's all . perfect time to replace the heater hoses too, & if you do you can just cut the old ones to remove the box. be gentle, the old boxes are brittle! I would also put a new foam kit in the box while your in there they aren't expensive. the 64-64's are like a mustang,which have cheap parts .not sure about the 63.
Ok, thanks.
