Horepower vs work
Horepower vs work
Postby boone » Tue May 15, 2018 6:04 pm
Ok im not sure if this is the right forum for this question or not, but here it is-I have a 65 caliente 2 dr hardtop with a 289 and automatic trans-eventually I will probably have the engine rebuilt and hopped up a little bit-im thinking somewhere between 300-400 hp, I also plan on doing the spring relocation kit-new front suspension and new rear leafs and trac bars-my question is what is the most horsepower you can get out of a comet before you have to start going through and adding a whole bunch of metal and braces to keep it together?-I also think I am going to do the subframe connectors on this car also-I wont be using the car for drag racing every weekend but would just like to have a fast little car. the car has the 2 barrel on it which I think was rated somewhere under 200 hp? and of course it probably isn't making that anymore but it still feels pretty peppy so I may stick closer to 300 hp. so to play it safe what (if any) mods would I have to do at 400 hp max? thanks.
boone
Re: Horepower vs work
Postby SASSY » Tue May 15, 2018 7:44 pm
Put 3-400 HP in it, it' be fine till you put traction tires under it.
Car will take it if it isn't too rusty,,, IMO
viewtopic.php?t=1288
Postby poboyjo65 » Wed May 16, 2018 11:55 am
I agree with Fred.You basically described my car :lol: except I have a 4sp..but you need better brakes with all of it. SFC's & your other plans of moving the leafs in sounds like you want wider tires. A stroker motor will get you in the power range you want without having to wind it so high. it will give you gobs of seat of the pants torque & increase the HP too. this will allow you to have the power you want & run a street friendly cam so it is fun to drive on the street. But if you're gonna go faster you need to stop faster so a disc brake upgrade is in order,,,,, not sometime down the road ,you need the brakes ''before'' you get the power! :lol: :lol:
347, 4sp, 9''
JOHNO
Postby boone » Wed May 16, 2018 6:24 pm
poboyjo65 wrote:I agree with Fred.You basically described my car :lol: except I have a 4sp..but you need better brakes with all of it. SFC's & your other plans of moving the leafs in sounds like you want wider tires. A stroker motor will get you in the power range you want without having to wind it so high. it will give you gobs of seat of the pants torque & increase the HP too. this will allow you to have the power you want & run a street friendly cam so it is fun to drive on the street. But if you're gonna go faster you need to stop faster so a disc brake upgrade is in order,,,,, not sometime down the road ,you need the brakes ''before'' you get the power! :lol: :lol:
Oh yeah I definitely plan on a disc brake conversion-found a wildwood 4 piston setup on summit for just under$600-thanks for the info-another question-with the spring moved to the inside of the frame what is the widest rim/tire you can run?-what do you have on the rear of your car?
boone
Postby poboyjo65 » Wed May 16, 2018 9:07 pm
You can get a more complete kit from csrp with 4 piston cal's & slotted rotors for about the same money.
I moved my frame rails in 5'' so I didn't use the spring kit from crites. there is a thread on here where a guy with a 64, I think he got 275/50/15's on his with spring relocator kit. ;
viewtopic.php?f=9&t=2250&start=165
if you cant see the pics let me know I have an add on, if you use google or chrome it will make all photobucket pics visible again.
347, 4sp, 9''
JOHNO
Postby A/FX » Wed May 16, 2018 9:40 pm
for the info-another question-with the spring moved to the inside of the frame what is the widest rim/tire you can run?-what do you have on the rear of your car?[/quote]
I may have mentioned this before so excuse me if I repeat myself.
I have 2.75x60x15 radials in the rear of my ‘64, they fit because I moved the springs 2 1/2” inboard on each side. ( and a few other tricks) The wheels I have are 15x8 with negative offset. The car sits low, not jacked up in the back. I built a 9” that has been narrowed to allow room for the tires.
'64 Cyclone
Postby SASSY » Wed May 16, 2018 11:39 pm
I also have 275-60-15 tires but on 10 inch rims.
It takes quite a bit more than just moving the springs.
Probably mod the wheel tubs, I changed the wheel openings completely but the stock ones would need mods.
It's work, not to scare you away from it just a heads up.
Postby SASSY » Thu May 17, 2018 12:07 am
Just ran across this on MSN home page.
https://www.msn.com/en-ca/autos/enthusi ... =AAxl78Y|1
Postby boone » Sat May 19, 2018 7:47 pm
Awesome info-Thanks a bunch guys!!!
boone
Return to Body Shop
Users browsing this forum: Bing [Bot] and 1 guest
