Gas tank drain plug
Gas tank drain plug
Postby tomb22 » Fri Jul 06, 2018 8:01 pm
I ordered a bung and plug to install in my gas tank. My question is; what is a good way to install it? Do I weld it, braze it, solder it or epoxy it. It's a steel bung that was used for early Mustang tanks and it has a lip on it.
Thanks
Tom
Re: Gas tank drain plug
Postby poboyjo65 » Fri Jul 06, 2018 8:40 pm
Tig weld is probably the best way, but a mig with gas would do pretty good. Is this a new tank? for a comet? & it doesn't have a drain already?
347, 4sp, 9''
JOHNO
Postby tomb22 » Sat Jul 07, 2018 10:00 am
It's an old comet tank with a plug and I broke the bung off trying to get the plug out. I drilled the plug and used a easy out which didn't work. I'm bad :(
Tom
Postby Rocket989 » Sat Jul 07, 2018 11:28 pm
x2 for mig or Tig! Man, I really want a gas tank! This winter...this winter!!
Rocket989
Postby tomb22 » Sun Jul 08, 2018 8:37 pm
Thanks Guys
I'm going to go with the mig.
Tom
Postby RideAndShoot » Wed Jul 11, 2018 9:27 am
Just in case it’s not obvious, run a torch over either the fill hole or drain(bunghole, lol) to burn off any fuel/fumes. That way you don’t get a nice surprise when you start the weld.
RideAndShoot
Postby tomb22 » Wed Jul 11, 2018 6:37 pm
RideAndShoot wrote:Just in case it’s not obvious, run a torch over either the fill hole or drain(bunghole, lol) to burn off any fuel/fumes. That way you don’t get a nice surprise when you start the weld.
Thanks Man
I plan on cleaning out the tank exceptionally well, then fill with water just up to the bung hole, then I'll torch it.
Tom
Return to Body Shop
