Door Alignment
Door Alignment
Postby deusamo » Fri Jan 29, 2016 2:37 pm
As you can see in this image (https://drive.google.com/file/d/0ByMhjc ... sp=sharing), the driver's side door isn't perfectly aligned. Granted, in the image the door isn't completely closed, but hopefully you can get the idea. Basically, the rear of the door is low by maybe an inch. This has caused some significant weatherstripping issues. I'm wondering how one goes about re-aligning the door. Is it difficult? It seems you should be able to loosen up a few bolts on the hinge, move the door and then tighten them. But, having never done this before, I may be missing something obvious.
deusamo
Re: Door Alignment
Postby fryedaddy » Fri Jan 29, 2016 5:00 pm
when the door is open can you lift up on it, is it loose, does it drop when you open it, do you have to hold up on it to close, if so it may need bushings.they look like washers and they are not too hard to change
fryedaddy
fryedaddy
Re: Door Alignment
Postby deusamo » Fri Jan 29, 2016 8:43 pm
No, it's not loose. It just seems to be out of alignment.
deusamo
Re: Door Alignment
Postby Lou's Comet » Fri Jan 29, 2016 9:46 pm
deusamo wrote:No, it's not loose. It just seems to be out of alignment.
Not hard to adjust, first take the striker pin ( the pin the door latch grabs ) off the post. Then close the door to see how it lines up. this should be done first cause if the pin is out of alignment the door will be out too when closed. Is door is still out of alignment then loosen the hinges on the post not the door. You wil need to remove the lower interior kick panel to get to that bolts the come from the inside, at least on my 65. After you loosen the bolts close the door and use some plastic wedges, paint sticks, or whatever fits to wedge/shim between the rocker and door to line it up, and wedge it shut. You could also use tape to hold it shut if the shims don't. Once you get it where you want go in from other side and tighten the hinge bolts. After you get the door lined up to your liken then put the stricken pin back in and adjust it so the door closes easy and securely.if the striker pin is too high or low it will pull the door up or down when closing. Pretty easy to do.
This is to adjust the gap between door and rocker, if the gap between door and quarter panel is to wide or tight then you would adjust it with shims.
Re: Door Alignment
Postby CALIFORNIA CALIENTE » Sat Jan 30, 2016 12:24 am
Lou nailed it!If the bolts for the hinges have been loosened before you may be able to use a 1/4 or 5/16 [can not remember,been A LONG time] wrench on the bolts from the out side [fender needs to be off],if not you need to do as Lou said!!Take your time!A bodyman told me you"Align the door to the quarter first as the quarter can not be moved"!!You can make them perfect,just takes time,cost is ZERO!! ROY.
CALIFORNIA CALIENTE
Re: Door Alignment
Postby Comechero65 » Sat Jan 30, 2016 1:25 am
Don't know about comets especially earlier than 65 but if they are the same as on a 65 falcon the bolts that attach the hinges to the A pillar once loosened can be turned from the inside as the ends of the bolts have a hex end, don't know what size, that you can turn the bolts from the inside. Then you don't have to remove the fender. You just have to get the bolts loose initially. Then you can adjust the hinges from the inside. Much easier way to do it.
Might also want to check the hinge pins and bushings for wear and replace while you are at it.
Comechero65
Re: Door Alignment
Postby Lou's Comet » Sat Jan 30, 2016 6:55 am
Comechero65 wrote:Don't know about comets especially earlier than 65 but if they are the same as on a 65 falcon the bolts that attach the hinges to the A pillar once loosened can be turned from the inside as the ends of the bolts have a hex end, don't know what size, that you can turn the bolts from the inside. Then you don't have to remove the fender. You just have to get the bolts loose initially. Then you can adjust the hinges from the inside. Much easier way to do it.
Thought Falcon and Comets shared the same hinges. My 65 Comet you have to loosen the bolts from the inside. The holes in the hinges that attach the hinge to the A pillar are threaded and the bolts come from the inside of car. Need to take off kick panel inside to get to the heads of the bolts that hold lower hinges to A pillar. And reach up behind dash to get top hinge bolts. You dont need to remove fender to loosen bolts.
(Edit)
Looked at some pictures. Seems the early hinges are like my 65 and bolts come from the inside of car and thread into the hinge.
Here is picture of the type on my 65
http://www.ebay.com/itm/64-65-FORD-FALC ... 3641.l6368
And here is picture of the early type
http://www.ebay.com/itm/62-FORD-FALCON- ... 3641.l6368
Re: Door Alignment
Postby CALIFORNIA CALIENTE » Sat Jan 30, 2016 11:31 am
Lou;YES,the bolts come FROM inside the car! What Ron and I are saying is there is a hex on the ends of the bolts,look at second photo! I like having the fenders off as it makes access easier! ROY.
CALIFORNIA CALIENTE
Re: Door Alignment
Postby Comechero65 » Sat Jan 30, 2016 2:43 pm
You know now that I think about it the bolts are as Lou and Roy mentioned, just the opposite to what I said. The heads are on the inside and the hex ends stick out on the outside. Makes it easier to adjust the hinges from the inside.
As Roy said it's easier with the fenders off bu still can be done with them on. Get the doors adjusted to the top, back edge and bottom first. Then you can adjust the fender for a good gap on the front edge.
Comechero65
Re: Door Alignment
Postby deusamo » Sat Jan 30, 2016 6:43 pm
Wow, great info. Thanks everyone!!
deusamo
Re: Door Alignment
Postby Comechero65 » Sat Jan 30, 2016 11:25 pm
Here's what the lower hinge looks like. You can see the hex end of the bolts sticking out. I think they were made that way to ease installation of the bolts on the assembly line. But once the bolts are loosened they can be turned from the outside as well as from the inside.
Comechero65
Re: Door Alignment
Postby deusamo » Sun Jan 31, 2016 6:27 pm
Thanks for the picture!! That actually brings up another issue, which just started yesterday. So, the arm in the picture that is on top that goes inside the spring...the point on the bend of that arm which is up against that bolt keeps jumping to the other side, which keeps the door from closing at all. Sorry if that wasn't specific enough. I'll try to snap a picture the next time it happens.
Anyway, I can pry it back into place with a flathead, but it's happening pretty consistently anytime the door opens beyond a certain point. From what I can tell, it looks like the bolt which the arm rubs up against has been rubbed down a bit over the years, so the arm just pops over it when the door opens enough. So...do I need to replace the whole hinge? Clearly I don't know the terminology here well enough to just order the bolt (is it a pin, instead?).
Thanks again for all the help! You guys are awesome.
deusamo
Re: Door Alignment
Postby Comechero65 » Sun Jan 31, 2016 7:30 pm
deusamo wrote:Thanks for the picture!! That actually brings up another issue, which just started yesterday. So, the arm in the picture that is on top that goes inside the spring...the point on the bend of that arm which is up against that bolt keeps jumping to the other side, which keeps the door from closing at all. Sorry if that wasn't specific enough. I'll try to snap a picture the next time it happens.
If that pin the the upper arm goes up against is tapered then it could pop on top. Also the rivet the upper arm pivots on is loose could allow that. Maybe that rivet can be tightened some. It the pin has a taper maybe it could be filed to get rid of the taper and straight sided. I don't think those pins are available so unless you can find another hinge to replace or steal the pin from. You could probably pull that pin out and reweld it and grind the shape back in and reinstall it. I think the pin has a spiral spines that tighten as it's pressed in place.
I assume your hinge is similar to the one in my pic. That is correct for 64 and earlier falcons and probably comets. Since mine was an early 65 it had carryover 64 hinges. A correct 65 would have been like a mustang in terms of the door stop. I could probably swap the lower hinges with the correct 65 hinge which I like better. then it would have an intermidiate stop point instead of being all the way open. Makes it tough when parked too close to another car or obsticle. The doors are long and the same length as a 2 dr so when they are open they need a lot of room. But will probably leave it as is.
Comechero65
Re: Door Alignment
Postby kevinshi » Mon Jan 06, 2020 12:21 am
Lou's Comet wrote:Not hard to adjust, first take the striker pin ( the pin the door latch grabs ) off the post. Then close the door to see how it lines up...
Lou this makes perfect sense to me... I assume that the door should be perfectly aligned without the pin installed. E.g. the latch and pin should not have any impact on door alignment - rather they are "neutral" to alignment. There only purpose is to latch/release the door - not to pull/push the door up/down in/out to fix what are really hinge errors.
Question: Having achieved perfect alignment w/out the pint... what then is the exact behavior expected from subsequent installation of the latch and pin? For instance is the door suppose to be rattle free? (Is the latch suppose to "grab" the pin tightly enough to have no rattle?). Also is the door suppose to "spring" off the pin when opened (e.g. door opening should require very little if any actual push/pull)?
Also do I need to install either the bumpers or the seal before setting the latch position? I assume NOT - that if the door is correctly aligned, and the latch/pin are also correctly installed, that the bumpers and seal would conform and not work against the otherwise correct alignment?
(My driver's door is perfectly aligned without the pin however my pin is loose (as a result you can wiggle the door it a bit (my seals are removed)). My passenger door is not perfectly aligned - the pin pulls the door down just slightly (maybe 1/16th of an inch) - if there was no pin the door would be slightly too high on the latch side. I am now thinking I may replace my pins with the stainless steel ones from Scott Drake... but I want to have a game plan so I don't screw it up...)
Thanks,
kevin
Thanks,
kevin
65 Caliente Convertible
5H25A525287
kevinshi
Return to Body Shop
