rust lotions and potions
Posted: Thu Mar 24, 2016 10:07 pm
There are no shortages of snake oil salesman when it comes to rust products. there are removers. convertors, inhibitors ,encapsulators ,primers ,topcoats .its almost endless.We need a good thread on the chemicals people have tried
some treat the problem chemically and some eliminate oxygen and moisture from getting in to stop the reaction.
I am getting close to media blasting my body and doors.Just waiting for it t dry up a bit
I was planning on using Eastwoods afterblast product on it to prevent flash rusting .(it says no rinsing required) I assume its phosphoric acid .Then I wash the car down with a wax and grease remover and then epoxy prime it.
Has anyone used Eastwoods after blast? their site depends on customers to supply answers it seems?
after a 2week test application on a sanded fender ,flaky black spots showed up .I assume its the phosphoric acid with the rust.
I would think you would want to neutralize any acid before painting over it. I didn't get a chance to see if it would wipe off with a little more afterblast.
I can rinse the bigger areas with water ,but I don't want to create another problem since I am trying to prevent it from rusting..
What should I be treating the areas that I cant get at with the media,and after blast
its a chemical soup I tell you.
Por 15 seems to be a popular item on this site an others,maybe I should spray that into those hard to reach spots.(ensuring not to plug the drain holes )
your thoughts on my ramblings?
