Steering Wheel Repair
mercuryman
Post by mercuryman »
Has anyone ever repaired they`re steering wheel? What should I use? I have a steering wheel that's cracked and wondered if its worth repairing. Thanks.
Re: Steering Wheel Repair
I use PC-7 epoxy from eastwood. good stuff. plenty of work time. sandable. I repaired some cracks at the hub & encapsulated the entire wheel, which was missing areas & brittle. I built it up to a fatter steering wheel. it was a pain but fixing a few cracks would be easy.
Comechero65
Post by Comechero65 »
I repaired cracks in a mustang steering wheel. Used marine epoxy to fill the cracks. Primed and painted. Still looked good 2 years later.
mercuryman
I started the steering wheel repair. I`m using PC-7. Stay tuned.
V out the cracks with a file or dremel tool, makes it easier to get them full with out voids. another trick I learned to do is put tape on each side of the crack,close to the edge. the sanding will be easier & when you get down close pull the tape & smooth out the edge it left. being careful not to sand out too much & have to reapply more epoxy.
vicegrip
Post by vicegrip »
https://www.jamestowndistributors.com/u ... rdener+Kit
I've tried a bunch of different epoxy fillers and they all shrunk and cracked after a while,including PC-7. This West System G/Flex 655 is good stuff and hasn't cracked on my last two wheels. It's a little thin and takes several coats but doesn't seem to shrink.They are a marine type company...maybe it's what Ron used.
I have repaired numerous steering wheels using epoxy. The main reason they crack after correctly repairing them is that when you get in the car you pull yourself in by using the wheel as an anchoring point. The steel frame of the steering wheel flexes and causes the repair to fail.
A good epoxy will not shrink. Another trick is to cut a groove in the wheel perpendicular to the crack and insert a small threaded machine screw with the head removed. This will bridge the damaged area and when the crack and the groove are filled with epoxy the repair will be strong.
Comechero65
The stuff I used came from the hardware store. Don't know the brand but it was in a rope like form and you knead the two parts together then use it. Never shrunk after two years but don't know how it is today a couple more years later.
AND OL POP is the world's worst for grabbing the whl and kinda of jerkin my way in ,not so much in the comet but when getting in one of my trucks that sit a tad higher...just a habit and one that I need to break myself from... :? :wink: pop
mercuryman
Some more pics of the PC-7 repair. I like this stuff.
Sands really well.
Almost ready for paint.
Looking good ! & oh so familiar! :lol:
Imagescreen capture software
Imagefree photo hosting
mercuryman
Looks great Johno. Nice job. Hope mine turns out half that nice. Got the primer on and it turned out pretty good.
Thanks. I could have made it better but I was burnt out on sanding.it has a few slight air pits. I think yours will look much better than mine. It looks great so far!! :D
I guess I need to dig my replacement wheel out and see if I need to repair it any, if I remember correctly it was crack free but haven't seen it in a few years. The one in my Comet is not too bad so I can't imagine I bought one worse than it.
mercuryman
Paint is on. I'm happy with it. Not perfect but much better then it was.
