rear seat supports location
cam204
Post by cam204 »
Hi everybody great looking site!!
i'm having trouble locating the rear seat supports on my 64 2 door hardtop
if somebody had the measurements or a good picture of the sheet metal would be much appreciated
ill try and upload a pic of what i'm talking about just in case i'm not explaining properly
Cam
cam204
Re: rear seat supports location
Post by cam204 »
here is a pic
sorry it will not let me post a pic
Cam
try using a host;
http://www.cometcentral.com/forum/viewt ... f=1&t=2448
are you talking about the back rest or the bottom of the seat?
cam204
Post by cam204 »
this is what i need to locate
Yea I had the same problem. you can probably tell where they line up on top of the tunnel right?,then basically just stay as straight as you can. I try & find a pic of mine. as far as the angle just keep the top flange level , the seat slides on that. they are called seat risers, & they will show but usually get covered in carpet or vinyl.
cam204
Post by cam204 »
i kinda thought that
ill post a pic after i tack them in ill keep them square to the inner rockers
thanks
Cam
These pics show about where they line up on the sides. they have some vinyl covers but if you look hard you can see the metal top flange;
Imagephotoupload
Imagephotoupload
cam204
Post by cam204 »
ya that looks just about dead on to what i got
Thanks!!
cam204
Post by cam204 »
Image[/URL]
it lined up almost perfect
thanks
That looks just right! :D so now you will need to weld on the mounts for the back rest part of the seat,right? seems like I had those measurements wrote down when I did mine. but if all else fails you put the seat back in place & get in the trunk to mark locations. I think they have some leeway sideways but must be pretty close from front to back.
cam204
Post by cam204 »
yup thats next
i will need to fab new ones as the old ones were rusted to nothing
its amazing what mice can do :shock:
