has anyone found a decent looking weather proof relay enclosure for the engine bay?
Bushamn makes a great looking one but it also has fuses which I don't need
I think 4 relays will be sufficient for the engine bay anyways I could get away with 3
Fan,headlights,AC and fuel pump which could go elsewhere if needed.
A buss bar/Terminal strip in there would be an added bonus for the feed
I could get an enclosure from an electronics store and make something but before I do ,I thought I would see what you guys have come up with
I could also use some waterproof relays for headlights and such and tuck them away up near the grill ,
I like the idea of a central location for serviceability. And something that will stand up to wet coast weather
clean wiring is a must on this build
do relays produce much heat if they are constantly energized such as for headlights and or cycling such as a fuel pump?
I could use waterproof relays and just cover them for neatness
weather proof relay enclosure for 3 or 4 relays
Re: weather proof relay enclosure for 3 or 4 relays
Sound's marine like. Try Marpac.
Ron set up his relays in Comechero really neat using an old regulator housing.
http://www.cometcentral.com/forum/viewt ... ays#p74579
Something like this ?
https://www.summitracing.com/parts/hla- ... leSwitchNo
Not sure if they get hot but kind of have me wondering now.
I have a old truck apt shop that has relay for fan. If I remember I'll let it run for a while and see if it gets warm
These guys http://www.littelfuse.com have what I am looking for and more .Some places call them PCD'S or Power distribution system ..makes Sense and on second thought I think an additional fuse at the relay is a good idea as the fuse in the panel would be of lower amperage for the relay trigger wire
great idea with the voltage regulator.
