weather proof relay enclosure for 3 or 4 relays
Posted: Mon Apr 17, 2017 9:31 am
has anyone found a decent looking weather proof relay enclosure for the engine bay?
Bushamn makes a great looking one but it also has fuses which I don't need
I think 4 relays will be sufficient for the engine bay anyways I could get away with 3
Fan,headlights,AC and fuel pump which could go elsewhere if needed.
A buss bar/Terminal strip in there would be an added bonus for the feed
I could get an enclosure from an electronics store and make something but before I do ,I thought I would see what you guys have come up with
I could also use some waterproof relays for headlights and such and tuck them away up near the grill ,
I like the idea of a central location for serviceability. And something that will stand up to wet coast weather
clean wiring is a must on this build
do relays produce much heat if they are constantly energized such as for headlights and or cycling such as a fuel pump?
I could use waterproof relays and just cover them for neatness
