trunk panel repairs
cairnscomet
trunk panel repairs
Post by cairnscomet »
Hi all
started a few rust repairs on the 64 vert and came across this area on join of rear quarter and trunk upper panel.
No rust here just filled with bog
Now my question is best way to repair - fill with gorilla glass or weld patch
http://i1156.photobucket.com/albums/p57 ... hjdmbz.jpg
Grant
1964 Comet Caliente Convertible 302 4sp
1966 Ford Ranchero 390FE - daily driver
1923 408W T-Bucket
Loner
Re: trunk panel repairs
Post by Loner »
Hard to tell where your talking about on the trunk from your picture. I'm assuming it is the area above the trunk lid on the right or left at the leaded seam. To fix this you need to take the lead out and remove all the rust if there is any. Then relead it or use a good metal to metal body filler like this stuff.
http://www.tcpglobal.com/USC-14060_4.ht ... RNKnBllDqA
cairnscomet
thats the spot ,rear trunk panel/rear glass
good idea about the aluminium epoxy that will be perfect
added a photo that should explain better the area I am talking about
http://i1156.photobucket.com/albums/p57 ... dts2h8.jpg
Grant
1923 408W T-Bucket
