Spot weld drill
Spot weld drill
Does anyone have any experience with Spot weld drill Blair or Dentfix Pro or Con I am trying to justify buying one since I do so much spot weld removal and I hate doing it with a hand drill and spot weld cutter. I just did all the welds on a replacement fire wall it reminded me how time consuming it is and how much I dislike it. Now I have to go and do all the same welds on the car.
Projects
65 Comet 421Stroker
70 Torino GT
Projects
65 Comet 421Stroker
70 Torino GT
Re: Spot weld drill
I have been using the Blair cutter for years.
http://shop.blairequipment.com/ProductD ... gIsvPD_BwE
Tried a few other ones over the years..even a expensive snap on one. Always preferred and had the best luck with the Blair. Plus you can buy the cutters and pilots separate once you have the arbor.
Re: Spot weld drill
Have never seen the need to get the special spot weld cutting bits. I just alter the end of a standard drill bit so it has a center point and two outer corners projecting forward. I do that right on the grinder wheel. Has worked well for me. If it gets worn or chipped I just regrind it to the same shape. One bit lasts a long time. In fact never had to make more than one.
Re: Spot weld drill
Blair is the best. Operate at slow speed as heat dulls the cutter faster. To me,the pilot is a joke as it likes to walk around and end up missing part of the weld so I drill a 1/8 hole first.
Ron... you can just buy the drill bit you speak of from the Dewalt drill rack. They do work good,any size you want.
Re: Spot weld drill
I was asking if any one has used the actual Blair spot weld drill.
https://www.nationaltoolwarehouse.com/E ... gKSQ_D_BwE
I work on this kind of stuff all the time I am looking to speed up the process. I use cut down drill bits most of the time. drilling a pilot for the blair hole saws is a must.
Projects
65 Comet 421Stroker
70 Torino GT
Projects
65 Comet 421Stroker
70 Torino GT
Re: Spot weld drill
I have purchased many drill bits over the years but have never seen any bits ground the way I do mine. Plus I probably couldn't resharpen it if I had one of those as they probably would need a special sharpening jig. But at this point in my life I'm not likely to need another since I won't be doing any major restores. Haven't worn out the one i've been using yet.vicegrip wrote:Blair is the best. Operate at slow speed as heat dulls the cutter faster. To me,the pilot is a joke as it likes to walk around and end up missing part of the weld so I drill a 1/8 hole first.
Re: Spot weld drill
Mine are sort of like that except I bring my corners out forward to more of a point. And I can do that right on the grinding wheel. Has worked very well for me. I knew about those bits but never tried one.
