Brake Spring ?
Posted: Thu Jan 11, 2018 10:41 pm
by tomb22
Is there supposed to be a spring between the brake pedal and the pedal frame to pull the pedal away from the fire wall on a 65. I was wiring up the brake switch and noticed no spring to pull pedal off the switch.
Tom
Re: Brake Spring ?
Posted: Fri Jan 12, 2018 5:10 am
by comethead
No sir. Never seen one.
Re: Brake Spring ?
Posted: Fri Jan 12, 2018 8:43 pm
by tomb22
comethead wrote:No sir. Never seen one.
Thanks Joe. I won't think about it again.
Tom
Re: Brake Spring ?
Posted: Fri Jan 12, 2018 10:49 pm
No spring on mine. The master cylinder should push it back if it has the right pushrod. did you change master cylinders? Some brake kits come with an adjustable pushrod . my csrp kit came with one but it was a 1/4'' or so too long. I didnt feel like it was letting the mc piston all the way back out. After cutting it I was able to get some noticeable slack. sounds like you may have too much slack? & may need a different pushrod.
