Exhaust -Behind rear wheel/quarter Pipe Pics request
power band
Post by power band »
Exhaust - Exit Behind rear wheel/quarter Pipe Pics request for some help:
... not actually my Comet but trying to get around to finishing exh. on '63 Wagon after @ 10 years.
has Maverick 170/T5 with work, Hooker duals with side exits now, want 'traditional rear of wheel' pipe exit not rear valance.
some pics of under rear quarter dual exhaust exits appreciated - especially a wagon
Thanks
currently:
Image .Image . Image . Image
Re: Exhaust -Behind rear wheel/quarter Pipe Pics request
My 65 Cyclone, nothing fancy... I can get under car pics if you like. This is just a couple I have in my phone.
I prefer mine to not be too visible from the rear, and slightly visible from the side.
Rootsy
Post by Rootsy »
Sat Oct 07, 2023 9:19 pm
Do you have a pick of how you mounted your electric fuel pump?
Like Jim’s, but NOWHERE as clean and nice.
Rootsy wrote:
Sun Oct 08, 2023 2:07 pm
I do not have a picture on my ipad to send to you at the moment. I am on the road returning from a hot rod event in Oklahoma, when I get back to the shop I would be glad to get a picture for you and post it here.
Rootsy
Post by Rootsy »
Thanks. Is that a Carter vane pump? I have a Holley Blue and was sitting under there yesterday looking for the best way to mount that thing and have the inlet / outlet lower than the tank.
This is where the PO mounted mine. The positioning is OK, but I plan to shorten them up some.
power band
thanks for pics - lots options with angle, slant etc. , the wagon has fat dual line air shocks and HD rear sway bar brackets to make it challenging.
Rootsy wrote:
Sun Oct 08, 2023 7:56 pm
The pump is a Carter, I do not use it as a primary pump because I have a Holley high volume pump on the engine. The Carter pump is wired to an oil pressure switch and toggle switch as a safety factor, I use it on demand. The lines are 3/8” NiCopp except the flexible line from the tank to the pump and the AN line from pump to the hard line.
Here are a couple of pictures of the pump.
Rootsy
Post by Rootsy »
