Hi again,
Thanks for the photo, explains a lot.
Mine has a large threaded hole in the bottom of the frame behind the rear spring hanger as well.
I'm not sure how clear that is in my earlier photo.
Is that also part of the weights or something else?
Derek
66 Cyclone Gt Convt
Re: 66 Cyclone Gt Convt
I'm down in the back and can't get that low right now. Try and post a photo.
Hi again,
Frame 1 photo is of the two holes behind the rear spring hanger.
They are not threaded as I first thought but are in the underside of the frame and have 3/8" plate reinforcing inside the frame.
The round hole is about 3/4" diameter and the oblong one is about 1 3/4" long and 3/4" wide.
Frame 2 photo is of the hole in front of the rear spring hanger.
It is in both sides of the frame and has relatively thin reinforcing sheet inside the frame.
It is about 1 1/4" long.
Could theses be associated with the counter weights?
Or maybe associated with a trailer hitch (whet we would call a towbar in Aus)
Hope this helps rather than further confuses the issue.
Derek
Derek
- Frame 2
- Frame 2.JPG (59.12 KiB) Viewed 2350 times
- Frame 1
- Frame 1.JPG (122.58 KiB) Viewed 2350 times
I think those are simply locating holes for manufacturing.
When the cars were left the factory either by rail or truck transport they were secured by chains, the end of the chain had a “hook” that fit into those holes. This made it easier and faster to secure them and eliminated the chance of the worker wrapping a normal chain around something that was not designed to hold the car during transport. ( rear end housing, exhaust pipe, sway bar, shock absorbers)Lip Ripper wrote:I think those are simply locating holes for manufacturing.
Later vehicles used stamped steel plates for the chains to attach to that were bolted to the frame/sub frame, these were sometimes left in place or removed by a dealer or tow hitch installer. (That is why restoration people pay good money for the correct plates today)
the shackle bushing sleeve is welded to a piece of metal shaped like the frame about 6-8 inches long & sits inside the frame to reinforce the whole area for the shackles. the holes are line up holes for this piece,which had to be put on the frame before it was put on the floor. if you look close you can see the edge of it sandwiched between the frame & bottom of the floor on pic 2.I had to rebuild this piece with new metal on my 65. I know yours is a 66 but it is probably similar.Lip Ripper wrote:I think those are simply locating holes for manufacturing.
I welded up those holes on mine to keep dirt out.
view from above without floor;
Thanks everybody.
You blokes sure know your way around these cars.
Derek
Derek
It's always interesting to learn new things about them. like what AFX Jim said about the transport chains. but it makes sense since those holes are reinforced. I cut up a partscar for parts & cut mine up pretty good but never would have known that if he hadn't mentioned it. I had heard & seen pics of the plates he mentioned. At least some of the early years had those too , bolted to where the bumper mounts are attached to the frame67Cougar wrote:Thanks everybody.
Derek
