62 Cometman
62 Cometman
Hey guys, ive been watching and reading and learning for a while and finally decided to join. I have a 1962 Comet, Corinthian white, with an aqua interior that i reupholstered, it has a 170 six that i rebuilt this last winter, more of a freshining up, ball honed the clyinders new bearings and rings, NOS metal shim head gasket, relapped and ground valves, shimmed springs, head machined .060 inch and all new gaskets, speed daddy dual outlet header, full 2 inch exhaust with thrush glasspacks that dumps right in front of the passenger rear wheel. 2.77 tranny rebuilt still using same old syncros cause no one cars to make a new set, rebuilt drive shaft and 7.25 rear with 3.50 ratio, american racing outlaw II wheels with BF Goodrigh Radial T/A rubber, scarebird 4 lugs disc brake set up on the front. Custom made adjustable monte carlo bar, currently in the process of making boxed upper and lower control arms and some "nicer" tie rod adjuster sleeves using some swedge tubes and lock nuts, after a complete front suspension rehaul i plan on going over to the rear and doing the same then installing both front and rear sway bars 1 1/8 inch front and 7/8 rear then future plans are a turbo 200 with a T-5 and 8 inch rear.
Re: 62 Cometman
I'm glad you decided to join. Welcome aboard. I don't know if it is just me, but it seems like there has been more and more 62 and 63's starting to show up. That's great! If you get the chance load some pictures, I'm sure everyone would like to see your ride.
Re: 62 Cometman
Re: 62 Cometman
Very Nice Ride!!! I'll bet it turns heads!
NP Dave
NP Dave
Re: 62 Cometman
Thanks! I know i got a long way to go still in some areas but id like to think its a decent driver
Re: 62 Cometman
Looks great! only thing, it puzzles me how it has the same shaped paint chipped on both sides of lower fenders. But I'd say it is a few notches above a decent driver.
Re: 62 Cometman
Those arent paint chips theyre rust holes luckily i have another set of fenders waiting to be reworked an mounted, which is a shame because the fenders on the car are neigh on perfect other than those rust holes
