My stable of ongoing Comet projects
Re: My stable of ongoing Comet projects
Postby gmsnowball » Mon Jan 01, 2018 11:31 pm
My 64 202 my wife wants me to rat rod. After stripping, priming and painting the engine bay, under floors and suspension, installing new brake wheel cylinders, shoes and hardware, nickel copper alloy brake lines all I have to do is install the dual bowl master cylinder, the 1968 200 CI engine and decide what transmission to use. I have a 2 speed that came with the Comet, another 2 speed from my 65 Ranchero or a 3 speed from my 64 Ranchero that was mated to a 302. It will look clean and neat under the hood and under body but just a bit shabby on the outside. That's what she want's so I'll be her Huckelberry. Hopefully she will tire of it soon and I can finish the body work and paint install new interior and make it my daily driver.
Gary
Oklahoma Somewhere
Just Outside the Neutral Zone
64 Comet Calentie Convertible
gmsnowball
Postby chendrick » Sat Jan 06, 2018 12:04 pm
Looks great. What did you use to strip the engine bay?
chendrick
Postby loman » Sat Jan 06, 2018 10:42 pm
Nothing to exciting, but I finished the brackets for the trans cooler.
loman
Postby gmsnowball » Sun Jan 07, 2018 9:04 pm
chendrick wrote:Looks great. What did you use to strip the engine bay?
Spot blasted all corners and crevices, used a small angle sander and DA sander on alll the large flat areas. In all it took several days but it was well worth it. Shot two coats of primer under two coats of Eastwoods under hood satin black paint. I was surprised that there was no rust anywhere in the engine bay or underneath. I consider it very lucky.
Gary
Oklahoma Somewhere
gmsnowball
Postby loman » Sat Jan 20, 2018 6:50 pm
I got my lifters back from Comp Cams and installed them along with the intake.
loman
Postby caseville cyclone » Sun Jan 21, 2018 12:40 pm
Loman what tires did you put on the back of the so called slow car? I looked at your pictures you posted of your tire clearance and they looked like drag radials. Andy
caseville cyclone
Postby loman » Sun Jan 21, 2018 8:21 pm
Andy,
Those tires are Mickey Thompson ET streets. P235/60r15.
loman
Postby caseville cyclone » Thu Jan 25, 2018 7:41 pm
Thanks Loman,I'm going to get some ET streets for my Comet. I'm going to get P255/60R/15 for my car. I had 28X10.5X15 Pro Sportsmans on the rear but they were just barely hitting the outer wheelwell. The M/T specs said the center section was 11.2 but measured 11.7 on my eight and a half inch Centerline Convo Pro wheels with 3 and 3 eights back spacing. The M/T radials specs say 10.1 center section,so they should fit real well even they come out less than 10.5 to even 11 inches mounted. How's that black car coming,did you get your engine back in? Andy
caseville cyclone
Postby loman » Thu Apr 12, 2018 9:23 pm
I see that i haven't updated this thread in a while. Motor is back in the black car and ready for a couple of test runs.
I did a compression and leak down check on the truck 390 and she is needing some work. I went ahead and pulled the 390 motor and trans from the truck and ordered a shock tower kit from Crites.
loman
Previous
Return to Showing Off
