Loman's '65 race car
Re: Loman's '65 race car
Postby loman » Sun Mar 03, 2019 12:20 am
I realized 3 different project on one thread was a bad idea. So Mike did me a favor and renamed this thread. Thanks Mike! I will make this thread for my black 65 race car. I already have a thread going for the 390 car and whenever I start working on the white car again, I'll start a new thread for it. Thanks again Mike.
loman
Postby popscomet » Sun Mar 03, 2019 1:51 am
MIKE'S,a pretty good king-pin..... 8) :wink: ….pop
Postby loman » Sun Apr 28, 2019 7:54 am
Good luck bad luck continues. Went to the local chassis builder where I originally bought brake pedal. They had never seen a pedal brake like mine did. The guy at the counter had to call a couple other people up front and show them my brake and they were all surprised. Anyway, the original part # was replaced with something else. They pulled out the new one and it was exactly the same other than cast aluminum bracket was painted black. I bought and installed it. Might make a stronger one later. Tested the brakes the best I could in the driveway which isn't much of a test and everything seems normal. 10 minutes later underneath the car in the shop I see a trail of water. The best I can locate the leak is between the timing chain cover and the block. Retightened everything but that didn't help. So it looks like I'm pulling the front of the motor apart. Bad luck = water leak, good luck it happened in the shed and not on the track where it could cause something bad. We didn't take the motor apart this winter, but it might be time to do another once over the whole car.
loman
Postby loman » Tue May 07, 2019 9:13 pm
I replaced the gaskets and then added water. I had the same leak at the same spot between the timing cover and block as before. So we took everything apart a second time replaced gaskets again and I used a different timing chain cover that I had on another motor. This time everything sealed up, so we started the car and built some heat and pressure in the engine and everything seems ok now. We will check everything again 1 more time and if all is good we will reinstall diaper and front end and hopefully go racing this weekend and test the new brake pedal assembly. Fingers crossed.
loman
Previous
Return to Showing Off
cron
