Ant's 65 Comet Build
65clevorcyclone
Re: Ant's 65 Comet Build
Post by 65clevorcyclone »
The motor had probably 10,000 miles with a stock 64 c4, changed to a mid 70's 26 spline trans and wiped out the thrust un a trip to puyallup good guys and back, fyi this all happened in my 63 falcon and not the Comet
ants875
Post by ants875 »
Wow that's a bummer, mine never made it past 100 miles before we had problems I've read of guys wiping them backing out of their driveway on a new motor.
You live in WA state?
Ant
65clevorcyclone
65clevorcyclone
ants875 wrote:Wow that's a bummer, mine never made it past 100 miles before we had problems I've read of guys wiping them backing out of their driveway on a new motor.
Ant
Im in Langley BC, approx 2 hours from Seattle, 20 minutes from the Lynden border crossing.
ants875
Post by ants875 »
So I drive the car again yesterday and reset the timing to 18 initial and 38 overall, feels a lot snappier so I think I'm going to leave it there until I can get it on a chassis dyno. I also got my ebrake working and out the defroster ducts back in. It was good to spend some time working on it and of course driving it.
Ant
Happy to hear you hand is back in operation and havin fun with your Comet!!
Tbart
Post by Tbart »
Ants, Very interesting thread. I admire your stamina with the bearing problem. I read the whole thing like a mystery novel. No real definite solution though or explanation of what caused this problem? I hope it stays good for you. Great looking 65. Great looking rims. I guess your rear 8.8 swap worked good? That press out tube & shorten then use the short axle is a good trick. You have some awesome skills!
Ant - do you have any recent pics after the new front springs settled down? I got the same ones but am doing the Shelby drop. Trying to figure out if I should get a little taller isolater (like 3/8" vs. 1/4") and/ or shim the perches to keep ride height where I want it.
Thanks man!! JH
ants875
Post by ants875 »
Jh,
I had it out today but didn't get any pics of it, I was going to post one I took about 2 months ago but photobucket is not working. the weather is supposed to be good hear again tomorrow so i'll get a couple new pics for you.
Ant
Thanks man!
Comechero65
Post by Comechero65 »
Rocket989 wrote:Ant - do you have any recent pics after the new front springs settled down? I got the same ones but am doing the Shelby drop. Trying to figure out if I should get a little taller isolater (like 3/8" vs. 1/4") and/ or shim the perches to keep ride height where I want it.
Thanks man!! JH
I had done the Shelby (Arning) drop on mine plus rebuilding the entire front end. I found for some reason the front sat to low for my likes. Don't know why and i don't think the shelby drop had much to do with it. Don't know if the springs were getting soft or if someone had replaced the springs sometime in its' past.
So i added the 3/8" donuts to the top of the springs plus I shimmed the spring perches up with a 1/2" spacer. Total effect was to raise the front end about 1 1/2". Much better now.
Ron - I'm doing the whole ball of wax as well. Springs are MOOG 8090's, same as Ant had used. I've read the drop will typically lower the front 1/2-3/4". I don't want the nose down at all!
JH
Comechero65
Rocket989 wrote:Ron - I'm doing the whole ball of wax as well. Springs are MOOG 8090's, same as Ant had used. I've read the drop will typically lower the front 1/2-3/4". I don't want the nose down at all!
JH
Can't say that I blame you. I didn't want mine so low that endangered hitting speed bumps and taking the heads of critters. The shelby drop is supposed to drop the front maybe 1/2" to 5/8" only. could be a little higher but is at a heigth I can live with now.
ants875
Post by ants875 »
I got a couple pics but still cant get photobucket to work, i'll try from my shop computer tomorrow.
ant
ants875
Post by ants875 »
JH,
here you go
hope this give you what you wanted
Ant
