I don't see how that would help get the results you want. For the fan to pull itself down sitting at idle.bigdan wrote: Ill start by saying if i'm driving, it'll cruise all day at 182 or so. I started the engine with a 1300 cfm electric fan controlled by a 175-185 switch. Cruising in winter temps, the fan would kick on if I sat in traffic for a while, but then kick back off once I started driving. If I left it idling, it would never kick off. So . . . Bigger fan. Stepped up to a 2500 cfm fan, same 175-185 temp switch. Still sits rock steady at 180-182 driving around. If I sit a minute in traffic, it'll turn the fan on at 193-194 and shut off once i'm moving around again, but idling in the shop it'll still never turn off.
In my mind, I think the fan should at least be able to pull itself down and shut itself down at idle. So, should I step up to a 185-195 switch? Is my idea of keeping it around 180 too low? What's the general consensus on a warmed over 331 standard operating temp - 190? 200? I just want to get this dialed in before I start some serious road time.
Any input is fine by me . . . . .
Dan
The temp switch 175-185 you have now fan turns on around 193-194 and for the fan to shut off you need temp to drop to 183-184, (10 degree lower?) and with the cooling setup you have now it is not capable to lower the temp 10 degree siting still idling.
Now if you go to a 185 -195 the fan should kick on around 203-204? Switch is ten degree higher? And kick off around 193-194? Your cooling setup will still need to pull the temp down 10 degree for fan to kick off. And if your fan doesn't do that now sitting idling I don't see how it would do it at higher temp?
What does temp go to/peak when sitting in shop idling? What temp thermostat in engine?
