289 and edlebrock linkage help
Re: 289 and edlebrock linkage help
Postby lavron » Mon Aug 12, 2019 10:05 pm
Jims65cyclone wrote:Check that scrap pile you keep going to behind your shed. You may have some. You've pulled all kinds of stuff out of pile to make something else you needed.
Everything is raw material, I don't throw out anything until it is totally unusable. After my uncle passed and we were cleaning out his garage and barn I picked up every bit of metal scrap I saw, I even have an old tractor drawbar that has the ends broke off, someday I will need some thick steel :P
Postby popscomet » Mon Aug 12, 2019 10:44 pm
I'd like to know how he broke both ends off a draw bar???? :? :shock:
Postby poboyjo65 » Mon Aug 12, 2019 10:45 pm
popscomet wrote:
poboyjo65 wrote:Pop I've had single cable throttle cable hang on a motorcycle. the cable frayed up inside the housing,so having a cable isn't a guarantee. later most of them went to what they called a push/pull double cable. but actually both pulled,,,, one on the twist grip to pull open the throttle & one to pull it closed. but I've also had one of these hard linkages on a car hang. that's why I pinned my motor mounts. still any throttle can hang no matter what you do.
thanks for the info,,,,have you ever dumped the clutch at such a high rpm and had so much traction that you broke a motor mount ??….on a everyday driven street car?
I plan to go bigger tires, 29/15.50/15s ,so ought to get decent traction . I'm hoping the big bolts that I put thru the motor mounts & intermediate mounts wont let that happen on this comet. & I was thinking back to when that hard linkage throttle hung when I decided to pin these mounts. I think it was a 72 cutlass, my first car.
347, 4sp, 9''
Postby popscomet » Mon Aug 12, 2019 11:22 pm
POP is gonna PM....I feel we are taken advantage of this thread....
Postby poboyjo65 » Mon Aug 12, 2019 11:41 pm
popscomet wrote:I feel we are taken advantage of this thread....
first time for everything! :lol: :lol: :roll: :P :P :) :D :mrgreen: :shock: :? 8)
347, 4sp, 9''
Postby Tancrede44 » Sun Oct 13, 2019 1:28 pm
poboyjo65 wrote::P
this is mine, simple .
& adjustable. I can make it shorter or longer.
quick disconnect,either end.pops off with a screwdriver. the carb end has a push lock clamp that snaps on a ball . I like all that :D
If you just had the carb end of one of these linkages with same thread as your linkage .
Hi all, I am of this opinion that this photo is important, it is interesting. I would like to know more if it is possible, thank you for your feedback  Good luck. Sincerely.
Tancrede44
Postby SASSY » Sun Oct 13, 2019 2:37 pm
Above post probably junk, spam or whatever.
viewtopic.php?t=1288
[urlImage[/url]
Postby poboyjo65 » Sun Oct 13, 2019 8:32 pm
SASSY wrote:Above post probably junk, spam or whatever.
ehhhh hmmm!! Careful what you're calling junk there Freddy that's a pic of my motor. & it aint askeered of no camper pullin over wound buzzin half dozen, so just bring it on! :lol: :lol: I'll out run you & ya camper at the same time!!! :lol: :D
347, 4sp, 9''
Postby SASSY » Mon Oct 14, 2019 12:27 am
Appears to be a pic of SOME of your motor! :lol: Yes that 347 will out run my "Half Dozen" but there was a time when Sassy could stand it's ground late on a saturday night.
But Saturday nights are short and now I like to be rollin down the highway smilin :mrgreen:
[urlImage[/url]
Postby poboyjo65 » Mon Oct 14, 2019 12:15 pm
Heh ,,just ribbin ya Fred. But I like the way he worded it. I dont know if it is spam or someone speaking another language. Didn't know what else to tell him about that pic, specifically. :?
347, 4sp, 9''
Previous
