Hi all,I am putting in a 20" wide aluminum rad with electric fan in my 65 for my 331 Stroker,and want to get my cutting and welding all my Fabrication done now on the rad support
I have the original Rad so I know were it used to fit but my car is stripped completely with no engine and wanted to get an idea how much room there is going to be between the motor and rad to ensure I don't have interference problems with rad/fan/shroud 2-12 years from know when I get it back together.
a measurement from the timing cover to the inside of the rad support would be great as that should be the same for all
or some other measurement would be most appreciated
Thank you
65 rad support to engine measurement required
