temp sensor location
Re: temp sensor location
Came back and took a 2nd look ,that blue intake could have the temp put in the center hole in front of carb on top,i'll get my 64 intake down and chech for sure as it;s orginal to my comet(64) pop
Took another look. On the blue one the one right behind the stat housing would be for the heater hose. The one behind the dist would be for the temp sender. My Edelbrock F4B is similar only my sender is more to the right of the dist but still close.
The 3rd now that I look closer must be a threaded (maybe) boss but not for either a sender or heater hose. The other intake only has one fitting.
