Drag strip tomorrow!
Matty
Post by Matty »
Anyone wanna bench race? I haven't ever ran the car so guess away. Most of my specs are in my sig.
Track
DA about 4500ft
90-95 degrees
1/4 mile track
1962 Mercury Comet S22 302 5.0 T5 Custom: tfs 1 cam & springs, 8.8 31 spline lsd 373 rear, 5 lug disc conversion front and rear, new V8 steering components, Gt40 heads, Performer RPM intake, phenolic spacer, Brawler 650
Re: Drag strip tomorrow!
I'm not any good at this but just to get this show started I'll say 13:45
Matty
Post by Matty »
I ain't either but it's just for fun. :)
So what is your guess Matty?
Matty
Post by Matty »
Well.... I am going to say 14.23 because of the heat, my holley 4160 isn't the best carb combo, and my tires are only 205s. Well I have also never staged at tree before either. Lol
Matty
Post by Matty »
I also don't want set my standard to high for disappointment. I rebuilt the motor and trans with goal of running a 13 but...
pugs65
Post by pugs65 »
I agree with Johno. Mine is estimated to run 12.85's in the quarter. I know you'll have fun, Pugs. :mrgreen:
302 roller
4 speed
Matty
Post by Matty »
Well bad news. My first pass ever was the only one that the car even made it down the track all the way. Lol I missed 2nd gear and let off the throttle before the finish. I ran 14.6. After that my car would fall on its face in 3rd. Those were all 15-17 second passes at 60 miles an hour. I guess my back barrels haven't been opening and didn't really notice because I hadn't really ripped passed 2nd.
It's a holley 4150 600cfm. Going to put a new diaphragm in and go back in a couple weeks.
Definitely got easy 13.x potential. 600DP's can be had pretty cheap since most folks go 650cfm. Give Edelbrock a call or nose around the Inet and try to find flow numbers on the intake. Methinks the current intake and carb are gonna hold it back a mite. The rest is hooking up and driving!! :lol: :D :o
My favorite on mild 302's is the Weiand 7515...it's a small single plane and has worked well on a few different 289/ 302's over the years. The newer Street Warrior has a good rep too - might bump up to 650cfm carb if using the dual plane!!
Good luck with it man!!
vicegrip
Post by vicegrip »
Matty wrote:Well bad news. My first pass ever was the only one that the car even made it down the track all the way. Lol I missed 2nd gear and let off the throttle before the finish. I ran 14.6. After that my car would fall on its face in 3rd. Those were all 15-17 second passes at 60 miles an hour. I guess my back barrels haven't been opening and didn't really notice because I hadn't really ripped passed 2nd.
As hot as it was,and if you have a mechanical fuel pump,the suction of the pump causes a slight vacuum in the fuel line to the tank and the fuel vaporizes.Odds are you simply ran out of gas. An electric pump by the tank,pressure properly regulated,would cure that problem.
Matty
Post by Matty »
Rocket989 wrote:Definitely got easy 13.x potential. 600DP's can be had pretty cheap since most folks go 650cfm. Give Edelbrock a call or nose around the Inet and try to find flow numbers on the intake. Methinks the current intake and carb are gonna hold it back a mite. The rest is hooking up and driving!! :lol: :D :o
Thanks for the input. This a 600s single. I would like to upgrade soon.
Matty
Post by Matty »
Yes I thought maybe the fuel pump also. It's a electric carter 4psi that up front. I might switch it to the rear. Thanks
-Rudy-
Post by -Rudy- »
I'd estimate your power around the 300-330 rwhp range, with good tires (DRs or slicks) on a car as light as these I'd say you'd be close to being in the 12s most likely.
1963 Mercury Comet Custom 2-Door Sedan
170/2-Speed Auto
Matty
Post by Matty »
-Rudy- wrote:I'd estimate your power around the 300-330 rwhp range, with good tires (DRs or slicks) on a car as light as these I'd say you'd be close to being in the 12s most likely.
Well we are going to try again a second time this evening. I don't have good tires but we are going to try to feather it in to the 13s tonight. I ran a 14.6 spinning, missed 2nd, and still managed 95 mph trap speed, so I think we can get it if the car doesn't give me issues again.
Matty
Post by Matty »
I moved the fuel pump to the rear with a 100 micron prefilter. Left the main filter up front, put the white spring in my 4160 and a different pv also. Seems to run a lot better and isn't starving for fuel. Wish me luck!
