Does anyone have a small block oil pan laying around they could measure for me, maybe even a rear sump fox body pan?
I have to custom build an oil pan for my 250 so I can have a rear sump pan and was wondering if I could use the bottom of a rear sump SBF pan and marry it to my 250 pan for the MII front end so I was looking for the measurement of mostly width of the V8 pan.
I can buy new SBF pans pretty cheap with the extended pickup (which I am sure I would have to modify) and of course there is nothing available for 250-6, I had thought to try and find a 200 rear sump pan and fit the two together but they are not that easy to find.
Just asking if someone has easy access to a pan they can measure, otherwise I can come up with something, there are a lot of engines laying around the scrap yard.
SBF Rear Sump Oil Pan (Fox Body?)
Re: SBF Rear Sump Oil Pan (Fox Body?)
I have one under my workbench still on a motor,I think it is from an early bronco,kind of a double sump. it looks just like the 5.0 motor pans though I'm not sure. do you want the measurement from bolt hole center to bolt hole center on width? I think I can put two framing squares together & use like a big slide caliper. I'll go have a look .
from outside of pan to outside in front is 9.5''. I couldn't get to the bolt holes.
No that will work John, thanks, I will measure the 250 tomorrow, it has been in the vat of degreaser for the last 4 days or so.poboyjo65 wrote:from outside of pan to outside in front is 9.5''. I couldn't get to the bolt holes.
I would just be using the pan bottom and not the flange anyway.
A sbf pan get more narrow in the back. If that is the part you need it will be less than the 9 1/2''. I can't get to the back of the engine right now to measure the back. I just happen to think about what you were thinking of doing, you need the rear part, right?
in this aftermarket diagram looks like 9'' wide at the rear sump so that's probably about what a stock pan is too.
https://www.cantonracingproducts.com/pr ... G-OIL-PAN/
This is the measure on the 250 oil pan.
Maybe I have something I can mod it looks like the dimensions are not too far off.
I'll check and see the if I have any Fox 'Stang pans @ the moment & measure if so!
I have a new double sump pan with pickup that came on my crate motor which I will never use. Probably not what you are looking for and may not be of any use to you but have it if it can be used by someone. Got a water pump and flywheel too.
Actually Ron that might be exactly what I am looking for, does it have the small sump on front and the larger one to the rear? I nerd to be able to get over the top of the MII crossmember and steering rack, shoot me a PM and we can we work out details if you are interested on getting rid of them, I would rather pay someone here than Summit or the like Of course I need to make sure it will work but it is looking like it should, I will need to fab the pickup as well I am sure, but hopefully I can attach the long SBF pickup tube to a 250 tube.Comechero65 wrote:I have a new double sump pan with pickup that came on my crate motor which I will never use. Probably not what you are looking for and may not be of any use to you but have it if it can be used by someone. Got a water pump and flywheel too.
That would be great Rocket if not too much trouble.Rocket989 wrote:I'll check and see the if I have any Fox 'Stang pans @ the moment & measure if so!
My hope is I can do this without ruining the 250 pan because I will have to go junkyard searching again if I do.
