Alternator drawing current with ign off
Posted: Thu Oct 05, 2017 7:49 pm
Having a problem with the battery going dead in about a week with no driving. PO told me he had this problem & put a shutoff switch on battery. Checking today I disconnected all wires from + battery going to the starter relay. Connected amp meter between +bat wire and other wires one at a time with key off.
One wire drawing about 40 ma that goes to radio (Aftermarket). There are 2 other wires swaged to same terminal. Haven't found where they go yet.
One wire drawing about 120 ma. This wire goes directly to Alternator. It is the only wire I see on back of Alternator. Does that mean it has a built in regulator? This same wire was drawing 160 am when I first checked then going from 100 am to 120 am after I started car & then shut it off. It took about 1 minute to get to 120am
What is going on with alternator causing it to draw current with ign off?
