Having a problem with the battery going dead in about a week with no driving. PO told me he had this problem & put a shutoff switch on battery. Checking today I disconnected all wires from + battery going to the starter relay. Connected amp meter between +bat wire and other wires one at a time with key off.
One wire drawing about 40 ma that goes to radio (Aftermarket). There are 2 other wires swaged to same terminal. Haven't found where they go yet.
One wire drawing about 120 ma. This wire goes directly to Alternator. It is the only wire I see on back of Alternator. Does that mean it has a built in regulator? This same wire was drawing 160 am when I first checked then going from 100 am to 120 am after I started car & then shut it off. It took about 1 minute to get to 120am
What is going on with alternator causing it to draw current with ign off?
Alternator drawing current with ign off
- alternator 2.jpg (82.84 KiB) Viewed 1231 times
- Alternator 1.jpg (88.28 KiB) Viewed 1231 times
Re: Alternator drawing current with ign off
Have the Alternator tested. Most likely a bad diode in the alternator. They act like a one way check valve to change ac to dc . If a diode goes bad it will drain the battery.
Projects
65 Comet 421Stroker
70 Torino GT
Projects
65 Comet 421Stroker
70 Torino GT
Going to take Alternator to the Auto Electric shop & have them check it out.
