5.0 HO in my 65 Cyclone or not?
Posted: Sat Sep 08, 2018 1:27 pm
by The Transplanter
Hi guys
I picked up a 40k mile 1992 5.0 HO with AOD. The intention was to put this into my 73 250 6 pot Maverick
But now I am considering the 5.0 & AOD for my Cyclone with a few choice mods instead! The 65 currently has its original motor which would then be pulled & used in the Maverick.
Whats everyones thoughts on this, yes or no ???
Cheers Al
Pics for interest
Re: 5.0 HO in my 65 Cyclone or not?
Posted: Sat Sep 08, 2018 11:26 pm
by Rocket989
Posted: Sun Sep 09, 2018 3:00 pm
by The Transplanter
Posted: Sun Sep 09, 2018 3:03 pm
by The Transplanter
Also will the AOD go in the 65 tunnel or will it need relieving?
Posted: Sun Sep 09, 2018 6:50 pm
by Rocket989
Not an AOD expert but the tunnel might need a little BFH’ing towards the front!!
Posted: Sun Sep 09, 2018 9:44 pm
by tomb22
I just put a 302 with a AOD in my 65. Had no problem with the tunnel but had to rework the long tube headers. The AOD is wider then the C4.
Tom
Posted: Mon Sep 10, 2018 5:17 am
by The Transplanter
Thanks Tom
Which headers did you use? And im guessing you had to alter the crossmember as well?
Im not worried about such mods, its just nice to know what lies ahead
Posted: Mon Sep 10, 2018 11:52 pm
by tomb22
The headers are a set of Doug long tubes that came on the car with a 260 in it, so I don't have any numbers.
Here is a picture of the redo on the cross member. Used the same cross member, but lowered it a little and welded a piece of heavy angle iron to it to mount the transmission mount on to it.
I had taken a AOD and installed the guts of a 4R70W in it to beef it up. I used the 4R70W output shaft so I had to use the 4R70W tail shaft housing, which is shorter. In the end the 260/C4 drive shaft fit perfect.
Tom
