Pump to Edelbrock Carb Fuel Delivery Question
masonjarz
Post by masonjarz »
Hi,
I'm going back to a mechanical fuel pump on my '67 Caliente which has a 351 Windsor and an Edelbrock carb (fuel inlet on passenger side). I would like to avoid rubber fuel line if I can but I'm having trouble finding a pre-made steel line or braided hose which will work for me. I would prefer not to bend a custom line.
I'd appreciate any suggestions. Thanks, Ed
barrys65cyclone
Re: Pump to Edelbrock Carb Fuel Delivery Question
Post by barrys65cyclone »
only option make a template send to classic tube and have one made.
Most ,if not all edelbrock carbs have an inlet on the driver side also. just thought I'd mention it in case you find one that is a little short. & they make a chrome hard line with a banjo fitting, long enough to get out in front of the carb away from the throttle linkages, where you could then add a braided hose or what ever.
masonjarz
Post by masonjarz »
Thanks Barry and Jo
