Engine temp
Posted: Wed Apr 17, 2019 9:48 am
by thrnelson
I am having a strange issue I need some help with.
My engine will not warm up. I have a 180 degree thermostat in a mild 289, I drive around and the engine will hardly get over 120. I pulled the thermostat out so I could test it and found it stuck open. It was held open by two small tabs on each side. I dis-lodged it and tested it in hot water. Around 140 it started to open and at 180 it was completely open. I cooled it off and it closed again. I reinstalled it and this morning drove to work, ambient temperature was about 38 degrees F and the engine barely got to 110 degrees. The drive to work is about 18 minutes. Before I pull the thermostat again and replace it I wanted to get your two cents.
My specific questions are:
How long does it take your cars with a mild 289 to warm up?
Have any of you ever experienced this issue?
Thanks,
Trent
Re: Engine temp
Posted: Wed Apr 17, 2019 11:06 am
May be the gauge or wiring? Mine (180°) warms up in about 5-10 minutes. Heater starts getting warm in 3-4 minutes, & pretty hot in 10. your heater would be a good way to tell if it is running proper in the mornings. if the heat gets warm fairly soon then your thermostat started out closed & is starting to open up.
