Coolant Overflow Tanks
Re: Coolant Overflow Tanks
Expansion tanks are not overflow tanks.
Interesting...link below explains the difference between overflow and expansion tanks. Also mentions expansion tanks in Galaxies and Shelby Cobras.Joe Travers wrote: ↑Sun Mar 06, 2022 7:59 pmThe early '60s big block Galaxies had expansion tanks.
https://blog.championcooling.com/2018/0 ... sion-tank/
Going to get a bit nerdy here and put my hydraulic engineer hat back on after 5 years retirement.JimsHot66 wrote: ↑Mon Mar 07, 2022 7:15 pmInteresting...link below explains the difference between overflow and expansion tanks. Also mentions expansion tanks in Galaxies and Shelby Cobras.Joe Travers wrote: ↑Sun Mar 06, 2022 7:59 pmThe early '60s big block Galaxies had expansion tanks.
The article sited is a little confusing concerning the early '60s expansion tank and the design/purpose of it and the later coolant overflow tank. It states the purpose is the same and later contradicts that statement.
The early '60s expansion tank was a precursor to the later recovery system. Early expansion tank and later coolant recovery systems are both designed to provide air cushion for coolant expansion during heat cycles. Both provide additional coolant capacity. Both are vented systems. The difference is the expansion tank allowed circulated coolant and provided more cooling system capacity than the recovery system.
If engine modification is done to require more capacity, best bet is to add recovery system or larger radiator (or both).
we have had to tie an M/T oil bottle on at the drag strip,,,or load it and go home,,and they frown very very hard over running anti-freeze in the rad at the dirt tracks.....pop
