One of those pretty stainless steel radiator hoses (the lower) failed on my car last night. Back in the day, the flex hoses were crap. Is that still the case? Any recommendations on what to get, or avoid? The hose is about 40" and has a few twists and turns. I think I want to avoid another stainless hose.
Also, I only got about 8 quarts of coolant out of this. Book says 15 quarts. Does the bottom end of the motor and heater really hang on to that much coolant? The radiator was mostly full before I pulled the hose.
Thanks,
Radiator Hose-Coolant Capacity
Re: Radiator Hose-Coolant Capacity
I was doing the break in on a 302 motor,alternating between 2000 & 2500 rpms & had one of those SS hoses pop off,top hose.spaying lots of coolant right back on the motor,brand new polished intake. hose was new ,but it's hard to tell if it's on far enough & good & tight because you cant see it for the chrome couplers. dont use them anymore. rubber is easier to clean anyway because it is smooth.
If a factory hose will not fit your car then make a pattern of what shape you need and look the the parts stores inventory. I was able to use formed hoses by cutting a hose from another vehicle to fit what I needed. It takes some time but the results look factory and replacements are easy to locate when the time comes. For instance here is what I use: upper radiator hose- NAPA 9412, lower radiator hose-NAPA7375, Heater hoses-Dayco 80398. I cut each hose to fit my application.JimsHot66 wrote: ↑Thu Jun 02, 2022 9:38 amOne of those pretty stainless steel radiator hoses (the lower) failed on my car last night. Back in the day, the flex hoses were crap. Is that still the case? Any recommendations on what to get, or avoid? The hose is about 40" and has a few twists and turns. I think I want to avoid another stainless hose.
Thanks,
That's pretty much what I did having the hose in hand, with no success (counter guy says "here's a tape measure, let me take you to the hoses").A/FX wrote: ↑Thu Jun 02, 2022 3:16 pmIf a factory hose will not fit your car then make a pattern of what shape you need and look the the parts stores inventory. I was able to use formed hoses by cutting a hose from another vehicle to fit what I needed. It takes some time but the results look factory and replacements are easy to locate when the time comes. For instance here is what I use: upper radiator hose- NAPA 9412, lower radiator hose-NAPA7375, Heater hoses-Dayco 80398. I cut each hose to fit my application.JimsHot66 wrote: ↑Thu Jun 02, 2022 9:38 amOne of those pretty stainless steel radiator hoses (the lower) failed on my car last night. Back in the day, the flex hoses were crap. Is that still the case? Any recommendations on what to get, or avoid? The hose is about 40" and has a few twists and turns. I think I want to avoid another stainless hose.
Thanks,
They really didn't have anything that was close, even considered joining 2 hoses together. I ended up buying a foot of straight hose and fixing what I had. Let it get up to 220 degrees, no leaks, so far.
I have one in stock @ my local Autozone- Dayco Hose C70443
Prefer NAPA but they don't stock one.
I should have taken a picture when it was out of the car... the water pump inlet is on the front, passenger side of the motor behind the alternator; the radiator connection is on the drivers side bottom. This thing is 40" long with 4 bends in it. The hose I used for the repair wasn't cheap. Hopefully it lasts a while.Joe Travers wrote: ↑Thu Jun 02, 2022 5:26 pmI have one in stock @ my local Autozone- Dayco Hose C70443
The 302 water pump has outlet on opposite side as original 289.
I had a 302 in my '65 Cyclone w/ a cross-over pipe I eliminated. It had stock 289 radiator.
Changed the water pump to match the radiator.
