Can someone confirm what 65 V8 mounts look like?
I have two sets of (supposedly) 68 mustang mounts and they do look like what you can buy new online.
I have attached some pics of one side of mine as well.
cheers
gary
65 frame & motor mounts pics?
- onlineV8cometMounts.jpg (72.5 KiB) Viewed 856 times
- 351518653_792583419039928_2854007202551267901_n.jpg (191.94 KiB) Viewed 859 times
- 351532292_232264182879320_5699401381035849871_n.jpg (202.84 KiB) Viewed 859 times
- 351490731_249194524422871_199705460385724360_n.jpg (227.88 KiB) Viewed 859 times
Re: 65 frame & motor mounts pics?
The picture of the new parts looks correct for a Comet with a 289/302. I would recommend that you “ pin” the rubber mounts especially if you are using a modified engine. I used a 3/8” bolt with a nyloc nut, tighten the nut so it is snug but does not compress the rubber, this way when/ if the rubber fails the bolt will hold the mount from separating and causing the engine to move. ( especially important if you have mechanical carburetor linkage)
Those are not 68 Mustang mounts unfortunately. I think the saddle mounts of 66-68 Mustangs are superior to 65 Comet mounts and are a direct bolt in. The good news, I guess, is that those do appear to be correct original style 65 Comet v8 mounts.
True. Yes I bought these at a swap last summer specifically for the comet anticipating a v8 swap.Boss/Cyclone wrote: ↑Fri Jun 09, 2023 3:01 pmThose are not 68 Mustang mounts unfortunately. I think the saddle mounts of 66-68 Mustangs are superior to 65 Comet mounts and are a direct bolt in. The good news, I guess, is that those do appear to be correct original style 65 Comet v8 mounts.
But I forgot about them, and got confused because I also have 68 mustang stuff.
Cheers!!
