Before getting started on the 3x2 project I got a couple of old Carter AFBs model 3826. They are from a 1965/66 Buick Special with the 300ci V8. Frequently referenced as 400 cfm, the smallest AFB. Then I got an Edelbrock F28 manifold to go with them.
Now I’m working on the 3x2 setup but I wanted to get the 2x4 ready to go also. Didn’t take much.
Pic1- fuel log. Probably has no practical advantage but I like the old style. The clamps are designed so cannot dig into the rubber h/t to A/FX for the reference.
Pic2- progressive linkage. Aftermarket options are clunky and expensive so for a few dollars I made it from scratch. The upper pivot point on the front carb is for direct or 1:1 linkage.
Pic3 and 4- air cleaner. Nothing is made for the old 4-1/8 carbs especially not in 2x4 configuration. So I made a base plate from 1/8 aluminum. I like the look of a round air cleaner rather than oval. Filter element is 14x2 and the top is cast aluminum from Summit.
260 2x4
Re: 260 2x4
The right hand piece is from Summit they call it a “throttle linkage quick disconnect”.
The left hand piece is about 4” of 1/2” round aluminum. I shaped it with a drill press and a WWII era milling machine I found for $250. But could also be done with a drill press and hacksaw and files. Happy to provide better photos if that would be useful.
Re: 260 2x4
Just wondering where you got the ends. I've mulled making linkage for mine using 3/16" heim joints and all thread.
Re: 260 2x4
I like 2x4 setups.
I would put one on mine ,but it would cost me power over my funnel web. I would like to find a tunnel ram though . I have a set of 1850's that just need kits.
Re: 260 2x4
Here is how I did the linkage on my Cyclone, the progressive linkage is reproduction, the accelerator cable is from a Fairmont. I fabricated the fuel log.
Re: 260 2x4
Jim, I've noticed that a lot of the hardware on your car is golden color. Did you have them anodized?
Re: 260 2x4
Jim,Jims65cyclone wrote: ↑Sat Feb 24, 2024 9:10 pmJim, I've noticed that a lot of the hardware on your car is golden color. Did you have them anodized?
I wanted something a little different so all the brackets, nuts, bolts, etc. throughout the car have been plated in “yellow” zinc. When I did the car in the 1970’s I chrome plated everything but I became tired of the look and the maintenance keeping everything polished. The zinc does not last forever so eventually I will have to freshen it up.
