I have a stock 302, and C4 in my 65 comet. i need to replace the carb. but i'm finding it would probably be cheaper to put on a four v carb .i know a guy that has a edlebrock performer 289 that he wants to get rid of (no carb). i see lots of the edlebrock 1406 carbs for sale. would this be a good choice to replace my 2v carb and manifold with? i'm not trying to make this a racer but i would like to gain a few more ponies if i can.
thanks
Greg
intake manifold
Re: intake manifold
GREG--I had same set up on bone stock 302,4spd,headers,in a 67 fairlane,worked very good...NOW before you buy a used alum intake,make sure the threads are good ,where thermostat bolts on..check it out don't get taken 'cause it's pretty,and you start daydreamin,,'bout how your motor gonna look...I've been there.....POP
Re: intake manifold
OK so i went ahead and bought the edlebrock 289 manifold from my neighbor all of the threads were ok. he also has a set of hi po exhaust manifolds. are these worth replacing my stock manifolds with. i don't have the money to install headders. will i see much difference? the manifolds i have are the stock ones that have the opening facing the firewall on both sides. thanks
greg
greg
Re: intake manifold
The stock 65 LH manifold has the outlet pointed toward the ground and crosses the pipe under the oil pan to the right hand pipe. The RH manifold outlet faces the firewall. You might have Mustang manifolds?arnie123 wrote: he also has a set of hi po exhaust manifolds. are these worth replacing my stock manifolds with. the manifolds i have are the stock ones that have the opening facing the firewall on both sides. thanks
greg
On the Hipo manifolds; I think Falcon/Comet Hipo manifolds were reproduced for awhile, but not anymore. They are more slender than the Mustang Hipo manifolds to fit the Comet engine compartment.
Larger exhaust manifolds cant hurt I guess.
Re: intake manifold
Is dual exht already on this comet?If yes,changing to hi-po manf is not gonna give much in return.but if no,then byall means put 'em on. THe qustion was,,will i see much difference? pop [ i'm not the sharpest kniefe in the drawer ]this stuff is JMO
