parts replacement
parts replacement
Postby primal1 » Tue Dec 12, 2017 10:05 am
I'm breaking down the comet for semi-rebuild. new motor, suspension, ect. are there any parts that cant be replaced. some of the rubber bits are dry and breaking off in my hand. the rubber strip under the hood mainly. when this was happening it made me think about seeing if there was even a replacement. whats the opinion of Steel rubber products. their the only one I know of. any other suggestion would be awesome.
primal1
Re: parts replacement
Postby bmmaurer » Tue Dec 12, 2017 11:47 am
Cowl seal is available as are most if not all rubber parts / seals / bushings
https://www.autokrafters.com/p-6775-hoo ... comet.aspx
Bruce
bmmaurer
Postby lavron » Tue Dec 12, 2017 12:07 pm
I bought from here, I haven't installed anything but the wiper bezel gaskets but everything looks well made.
http://www.parts123.com/parts123/yb.dll?parta~partsort~1~cadffeja~~20
Postby lavron » Tue Dec 12, 2017 12:08 pm
Oh and just as a side note, they refunded part of the shipping cost to me, they said the website overcharged in it's calculation, nice that they would do that and not just pocket the difference.
Postby poboyjo65 » Tue Dec 12, 2017 12:41 pm
I have always heard that Dennis Carpenter has the best weather stripping for comets, falcons & trucks. though some pieces are not available from them.
347, 4sp, 9''......
JOHNO
Postby primal1 » Sat Dec 23, 2017 7:22 am
what are the rubber pieces called that go between the fender and radiator support. also the rubber between where the fender meets the firewall. they are held on with staples through the metal. i cant find these listed anywhere but not knowing what to call them could be hindering my google search.
primal1
Postby poboyjo65 » Sat Dec 23, 2017 11:26 am
primal1 wrote:what are the rubber pieces called that go between the fender and radiator support. also the rubber between where the fender meets the firewall. they are held on with staples through the metal. i cant find these listed anywhere but not knowing what to call them could be hindering my google search.
Splash seals ,here are some for example;
https://www.falconparts.com/ford-falcon ... s-c144.htm
347, 4sp, 9''......
JOHNO
Postby primal1 » Tue Dec 26, 2017 4:52 pm
thanks. are the falcon ones the same for a comet.
primal1
Return to 60 - 63 Comets
