carpet replacement
carpet replacement
Postby captian_napalm » Sat Jun 30, 2018 3:55 pm
Ok so the original carpet in my 62 resembled anything but. I have a new carpet to install. my main question is the placement of the gas pedal. Does it sit on top of the carpet, or do I need to make a slit?
captian_napalm
Re: carpet replacement
Postby poboyjo65 » Sat Jun 30, 2018 5:24 pm
It sits on top.
347, 4sp, 9''
JOHNO
Postby captian_napalm » Fri Jul 06, 2018 8:52 pm
thank you.
captian_napalm
Postby captian_napalm » Fri Jul 06, 2018 8:54 pm
Ok next question... The original carpet was garbage. How do I go about installing without having the old on as a template.
captian_napalm
Postby poboyjo65 » Fri Jul 06, 2018 9:58 pm
Not sure what you're asking. if you buy a new carpet set they usually come slightly larger & are trimmed during installation . AFAIK.
347, 4sp, 9''
JOHNO
Postby captian_napalm » Sun Jul 08, 2018 3:32 pm
poboyjo65 wrote:Not sure what you're asking. if you buy a new carpet set they usually come slightly larger & are trimmed during installation . AFAIK.
Basicly asking how to install this without screwing it up. Every thing I found calls for using the old carpet as a template.
captian_napalm
Postby rjones35 » Wed Jul 11, 2018 7:26 pm
So did you buy just a big piece of flat carpet or a molded kit, for your car?
rjones35
Return to 60 - 63 Comets
