63 Convertible seats HELP!!!
Postby GERK » Wed Oct 02, 2019 8:41 pm
I am not really having a hard time sourcing most of my needed parts.
I am however stuck with the seats.
1963 Comet Convertible s22
The rear seat is just rusty springs that break when you touch the seat
The fronts are pretty much the same. Just slightly better.
Has anyone had this issue?
Where do I get seats? The upholstery seems easy to locate. Just not the bases and springs.
Are there any other cars that will work? Besides possibly a falcon?
Thanks all
GERK
Re: 63 Convertible seats HELP!!!
Postby rhead63s22 » Mon Oct 07, 2019 10:37 pm
Falcon seat are the same...
rhead63s22
Postby bmmaurer » Tue Oct 08, 2019 7:15 am
Early Mustang buckets should also be very close
bmmaurer
Postby poboyjo65 » Tue Oct 08, 2019 11:43 am
bmmaurer wrote:Early Mustang buckets should also be very close
bolt spacing is a little different, you'd need to drill new holes,probably 3 on each seat.or make adapters. but they would fit just fine in the car. but comet upholstery may not fit.
347, 4sp, 9''
Postby Bagger » Wed Nov 13, 2019 11:56 am
rhead63s22 wrote:Falcon seat are the same...
So ideally, I can buy the replacement Falcon foam for my Comet? Or possibly Mustang seat foam?
Bagger
Postby bmmaurer » Wed Nov 13, 2019 2:08 pm
viewtopic.php?f=15&t=15922
These will work.
Comet Bruce
bmmaurer
Postby bmmaurer » Wed Nov 13, 2019 2:10 pm
I used falcon foam with slight modifications.
Comet Bruce
bmmaurer
Postby poboyjo65 » Wed Nov 13, 2019 2:18 pm
bmmaurer wrote:http://www.cometcentral.com/forum/viewtopic.php?f=15&t=15922
These will work.
Comet Bruce
Those may be for a hardtop which are different than convertible seats. tracks are different & they sit higher (hardtop seats).
347, 4sp, 9''
Postby Bagger » Wed Nov 13, 2019 2:21 pm
bmmaurer wrote:I used falcon foam with slight modifications.
Comet Bruce
What kind of modifications?
Bagger
Postby Lip Ripper » Wed Nov 13, 2019 2:29 pm
And the Stang seats have a much lower profile.
Lip Ripper
Postby bmmaurer » Thu Nov 14, 2019 6:40 am
The foam in this area needed to be cut to be narrower across the top edge to accommodate a different thickness of the area.
Bruce
bmmaurer
Postby Bagger » Wed Nov 20, 2019 1:55 pm
bmmaurer wrote:The foam in this area needed to be cut to be narrower across the top edge to accommodate a different thickness of the area.
Bruce
Gorgeous car! Can I ask what pieces of your interior needed replaced and how hard they were to obtain or where you got them?
Bagger
Postby bmmaurer » Thu Nov 21, 2019 7:11 am
Dash Pad replacement from Just Dashes... http://www.justdashes.com/
NOS seat covers and Repo Door Panels, seat foam from Jake at https://www.falconcometinteriors.com/
Carpet form ACC
Comet Bruce
bmmaurer
Return to 60 - 63 Comets
