sbf
captian_napalm
sbf
Post by captian_napalm »
I am looking to put a 289, or a 302 into my 62 comet. What I want to know is how much modification needs to be done to the front end, and will a 302 fit?
Re: sbf
yes a 302 will fit. you'll need v8 motor mounts & frame mounts. Most people upgrade to 65 v8 steering & an 8 in rear when moving up to a v8. the 65 steering is much improved & cheaper to replace. some parts may not be available for 62 steering. you'll need 65 spindles too but you are then set up for a disc brake upgrade. these is the cheapest ,most complete kits & you can get spindles in a kit too;
http://www.discbrakeswap.com/Mustang%20 ... TALOG.html
captian_napalm
Re: sbf
I read something somewhere that the 65 spindles had a tendency to break?
Re: sbf
I'd like to see it, first I've heard of it. If you're worried about that, the ones in the csrp kit are beefier I think ,,than reg 65 spindles, they're like a late 60's mustangs.
Matty
Re: sbf
Post by Matty »
You will also have to consider oil pan, the engine crossmember, radiator, and the most awful part..headers and trans crossmember depending on your combo.
1962 Mercury Comet S22 302 5.0 T5 Custom: tfs 1 cam & springs, 8.8 31 spline lsd 373 rear, 5 lug disc conversion front and rear, new V8 steering components, Gt40 heads, Performer RPM intake, phenolic spacer, Brawler 650
Matty
Re: sbf
Post by Matty »
It was worth it for me but quite the under taking imo.
captian_napalm
Re: sbf
Matty wrote:You will also have to consider oil pan, the engine crossmember, radiator, and the most awful part..headers and trans crossmember depending on your combo.
I like the stance of your comet....what did you do to get that look?
