Export brace
Export brace
Finally getting around to installing my export brace!! Aluminum bracket bolted to the firewall with tubes with rod ends going to aluminum pieces on the shock towers. Question is, once everything is bolted together, do the rod ends need to move? Arent they really just for adjustment? My issue is binding at the bracket on the firewall. Installing a little spacer between the rodend ball and the bracket and one between the the nut and the ball takes care of the bind, but the rodend doesnt move a lot, but not binding.
Re: Export brace
The exp
Re: Export brace
The stock ones were all hacked up when I got the car, so I replaced them with these. I did get some thick washers that worked for the rod ends, so that part is good. I'll see how these do, gotta be better than none at all.
Re: Export brace
I guess you have enough rain. No they don't ''need'' to move. in fact the stiffer the better. even though I think the original bolt on type export brace is stronger I dont think it would make enough difference for me to spend the money to change it if I were in your shoes, & may not clear your breather & that may be the reason you made that kind of brace. seems like I remember you having to change it,,, spread these out in the back to clear the breather that you made ,maybe?
Re: Export brace
poboyjo65 wrote:I guess you have enough rain. No they don't ''need'' to move. in fact the stiffer the better. even though I think the original bolt on type export brace is stronger I dont think it would make enough difference for me to spend the money to change it if I were in your shoes, & may not clear your breather & that may be the reason you made that kind of brace. seems like I remember you having to change it,,, spread these out in the back to clear the breather that you made ,maybe?
Yeah, the bars were originally quite a bit longer, made BEFORE the intake and air cleaner. Had to shorten those and make a new piece for them to attach to. I've got that piece bolted to the firewall with two bolts, how much stress is that thing going to be under? I know there's not much support up front. I did add a crossmember under the engine to help tie things together.
Re: Export brace
You'll be fine,no worries. lots of people run that kind. I think Roy even had them on his racecar.
Re: Export brace
That's Good! I've had nothing on there up until now, and I got to thinking "what if there really is a lot of pressure on these things, are they going to coming jabbing through the firewall at me!!" That would be a bummer.
Re: Export brace
All put together, well that part anyway.
Re: Export brace
delete
Re: Export brace
That looks great!rjones35 wrote:All put together, well that part anyway.
And no worries about it being a weak design; you're in good company. Alston Chassisworks make a similar brace
https://www.cachassisworks.com/Attachme ... DS_WEB.pdf scroll down
Re: Export brace
That looks great Rob!
I have one of the factory type bolt on Export braces & I can guarantee you it WON'T fit with your breather without ''major'' changes!
But if you want to make it stronger you could alter it to look like the one in Joe's link with a monte carlo bar .
Re: Export brace
RJONES,THOSE TUBELAR braces will work just fine,,,we use it on these dirt track cars for braceing all the time and I know for a fact that one of these dirt cars take more of a beating in one night then anything we all own take in a life time,,our M carlo bar runs from side to side and is fasten with a 5/16th bolt on each end,,and it is a tube like you have,just last year ,son got hit and knocked into the concrete wall and it moved the entire front end over a few inches,that tube never bent swayed or buckled a bit,,,but we found welds on other braceing that was torn and split,,but that tubular bar held it's own,,,,,,and another thing,,,jmo...what you have is nicer looking then anything you can buy,,,all these braces you buy look to dang gawdy to me,,,,like I said--JMO.....and if you try hard e'nuff,a man can tear up an anvil......opinion's are like butts.....we all have one
Re: Export brace
all the rear bars and front end bars on a open wheel modified are tubular,,all the adjustment bars are tubular,,cause they are strong and they all have the same ends that RJONES has on his s tower braces,,they are better then a stamped piece ,,,who ever says different hasn't been around the block to often and for sure hasn't ever built a race care to run on the dirt...tubular bars and swedge tubes are tough....and they are light in weight savings,,that's why they are used......
Re: Export brace
[quote="poboyjo65"]That looks great Rob!
john are SNORTIN powered Kool-Aid again ??....or you think someone else is ??
