Can’t find the right lug nuts need help??
I have some aluminum mag wheels for my 63 comet . They came off a falcon it is 1/2 20 the lug hole is bigger than a .687 what would you suggest about a slightly bigger lug shank. I am out of ideas input wanted ?
Re: Can’t find the right lug nuts need help??
Maybe they take a special washer? Or some oddball lug. Do you have a pic?
I can text
1 3039996255
1 3039996255
If you know the brand of the wheels, try Googling "lug nuts to fit _____ mag wheels".
If they have the ''tapered'' holes & tapered lug nuts then that should hold the wheel centered correctly .
TheLugNutGuys on ebay will have what you need. Sounds like you may need a shanked lug nut. If the seat isn't tapered, you do.
SW
SW
These are the rims
- 39AA36EC-2B3D-4815-84A3-85BF1D5AB9EF.jpeg (208.96 KiB) Viewed 3663 times
Looks like shanked with washers. Time to get the calipers out.
They are smaller than .740 any suggestions
I cant tell from those pics,are the seats tapered or just flat counter-sunk?????? some wheels had washers that fit the wheel tight in the recesses & tight in the shank of the lugnut, & that is what held the wheel centered. most now days are tapered for alike lugnuts which centers the wheel.
bet those whls are old,,but they still look good and they will look real time correct on the car...they will be well worth the trouble getting them on the car...good luck and thanks for the picture....POPpoboyjo65 wrote:I cant tell from those pics,are the seats tapered or just flat counter-sunk?????? some wheels had washers that fit the wheel tight in the recesses & tight in the shank of the lugnut, & that is what held the wheel centered. most now days are tapered for alike lugnuts which centers the wheel.
Hey Owen, just take a wheel to a auto parts shop that has has someone over 40 working there and sells aftermarket stuff, lol
I'm sure they will be able to help.
Look the same as the wheels on my camper except mine are5 on 4.5
I use a normal shanked acorn with a small washer.
If yours have a recess for a washer get one that fits the recess and the shank .
I do think that wheel is centered by the shank of the lugnut though.
I really want these to work sense they look badass they are not tapered in the lug hole
- IMG_E2574.JPG (184.39 KiB) Viewed 3605 times
https://www.carid.com/ic/dorman/lug-nut ... 56-1_1.jpg
I would be really surprised if these didn't work.
Widely available.
Widely available.
