rear end
Re: rear end
It should fit, the Maverick/Comet from the '70s is the narrowest 8" if you can find one, helps with tire clearance if that is an issue, I directly bolted a '71 Maverick rear into my '64 Comet.wvfarmboy wrote:what are you men using for rearends i have a 61 comet will a 64 falcon 8 inch work? what else fits easily??
