carpet replacement
captian_napalm
carpet replacement
Post by captian_napalm »
Ok so the original carpet in my 62 resembled anything but. I have a new carpet to install. my main question is the placement of the gas pedal. Does it sit on top of the carpet, or do I need to make a slit?
Re: carpet replacement
It sits on top.
captian_napalm
thank you.
captian_napalm
Ok next question... The original carpet was garbage. How do I go about installing without having the old on as a template.
Not sure what you're asking. if you buy a new carpet set they usually come slightly larger & are trimmed during installation . AFAIK.
captian_napalm
poboyjo65 wrote:Not sure what you're asking. if you buy a new carpet set they usually come slightly larger & are trimmed during installation . AFAIK.
Basicly asking how to install this without screwing it up. Every thing I found calls for using the old carpet as a template.
rjones35
Post by rjones35 »
So did you buy just a big piece of flat carpet or a molded kit, for your car?
