260 V8 power steering idle control valve
Does anyone have a source for these parts for my 1963 S22 convertible?
- Comet power steering idle control vave.jpg (185.19 KiB) Viewed 630 times
Re: 260 V8 power steering idle control valve
I'd say that's a hen's tooth. My 64 has one and it still works, but I've looked around and never found another one. They only used it on the 260 in 63 and 64. Once the 289 came out, I think they dropped it. Unless you have AC, you should be able to get by without it. Might need to increase your idle just a tad, but I seem to recall that about 650 rpm, mine worked fine, when I crank the idle down to 550 or so is when it is more necessary. Are you having trouble with it stalling when you go lock to lock?
If you are desperately in need, make this guy an offer, but I'm with Groover.
https://www.ebay.com/itm/265147165627?_ ... p_homepage
Dang Joe! Good find. And NOS
Check out that dude's stash of parts, Joe.
Joe II
Will do thanks Joe!
