No updates that I have images of. I havnt uploaded to photobucket in a long time.
All that has been changed is the seat rails. I need a few more inches of leg room. I'm 6'6". Now if the full back position, I cant touch the pedals!
Casey
62 comet, Miata Drivetrain Build
Re: 62 comet, Miata Drivetrain Build
I had the same issue with needing more leg and belly room. So I removed the rear shelf under the window in the ranchero. The shelf was in the way. It was either remove it or radically alter it. Removing it was the easier solution.
Then I moved my seats back 4". Switched to a GT woodgrain wheel as used in mustangs as it is slightly smaller od. All this made a big difference.
